If you knew as much as me you would know about 1% fella, back to the original post, if you move the DB and add bonding will you need to certify? will you need to put it through building control? is the original supply adequate for 5 showers? will 2 rcds be enough for 5 showers, a cooker and all the sockets in the house with all sorts plugged into them? does the 3 mtr rule really matter in this case as a cubicle has been added to a bedroom? if it does matter is it your problem or will you just need to mention it on the certificate? thats if you need to add one, thats one of the first questions I asked, have you got insurance to cover any works carried out on this your M8s property?
Have fun.
