I
i=p/u
As title says .. Ive heard earthing nuts but do you not normaly just gland to plastic and attach fly lead as normal
If you have a 20mm or 25mm gland you could use a metal "straight thru" conduit box, bush one side to the plastic box, the other will take the gland,
then connect an earth fly lead to the conduit box, there is a 4mm tapped thread in the box for this. Hope this helps.
Can do either, but why buy earthing nuts when everything you need will come in the gland pack, as long as the cpc continuity is there.
