L
lofty84
thanks trev. HOw would they do that though as surely any new cable would have a cpc, L, and neautral unless they cut it of then it would be there for them to use.
or do you mean Mr Jones decides to put an outside light at the front of his house right by the front door so he can see where the hole is for his key as he is fed up with it taking 5 mins every night through the winter. Instead of logically taking his feed from the the hall light for example he has decided that he will take it from the outside socket which was installed to power his lownmower when he wants to cut his front lawn because it was a shorter route. therefore when I go in and switch the mcb of for down stairs lights if I wasnt to double check it was dead then I would get a shock because there was still power feeeding it from the outside socket which was on the down stairs ring?
