T
teto
Hi all, was ask to go and look at a temporary supply for a new build on an old farm.
The mains has been moved to a small hut with a 4way garage cu
63A 30mA rcd 2x 16A mcb's, Cut-out has 60A fuse fitted
Has a 3/8 1.2mtr earth rod just under supply pole
240V mains present but as soon as you draw to much off the single socket it trips
will charge a mobile and run a lead lamp but drills, grinders all gwo, trips out
I have read the treads that say it should have a 100mA S type rcd and more rods or,
could it be a supply problem.
will be carrying out further tests soon for now only voltage. Any help before my return would be great. Thanks
