P
Plonker 3
im not changing any cu yet!! i'll ask you a question rob2 when you first started out in this game were you competent enough to change a cu? i'll answer it for you no you were not. I asked a question regarding rcds as i am qualified to extract a mains fuse from the dno cutout which allows me to work safely on an internal supply now if i know im not qualified to change a cu what do you think im going to do instead maybe fit a dp isolation switch or rcd? this is why i asked the question to see wether a rcd would be better than a bp isolation switch which i am competent to fit. maybe these so called "electricains" who seem to think having a dig at someone is amusing ought to ask them selves a question are you's competent enough to hold down common sense conversations or just silly remarks?? if it the latter then be gone with you
This post sums up your poor attitude, good luck with getting any answers when you respond like that.
