T
Tamaska
Too cheap buddy, also check out the minimum requirements for twin socket outlets in a kitchen re-wire..6,8 or 10 depending on size of room...
The kitchen is tiny (dont know exact size) barely enough room to fit my two double socket outlets and switch bank for the appliances above the work top. Baring in mind fridge/freezer, dishwasher and extract hood will all be controlled from the switch bank I thought 3 doubles would be plenty. One of the doubles is going low level by the back door and the other two as mentioned above the only bit of work top they can. Tried to price it based on my current rate at work. I think I can have the first fix done over the weekend then go back to second fix and test on a third visit.Too cheap buddy, also check out the minimum requirements for twin socket outlets in a kitchen re-wire..6,8 or 10 depending on size of room...
