W
wannabesparky
Hi as i am still learning i was just wondering if some one could clarify if the following is correct.
2.5mm twin & earth from the consumer unit to a fused spur with a 3 amp fuse in it by the combi boiler
then a 0.75 heat resistant flex from the fused spur to the combi boiler
then a 1.0mm 3 core and earth from the combi boiler to the room stat with connections made inside the boiler.
please only sensible answers as i want to learn everything but this is something i havent had to do yet.:confused:
Yeh, we use 1.5 / 3x core and earth, but what we do is also install a double surface appliance box at side of boiler or where convenient, use 1x for spur and the other side for you stat wire, this enables you to use another h/ resis/ flex into boiler, cable tied together, just neatens things up a little, then you havent got a pvc/pvc cable actually in the boiler panel, they are both heat resis.
thank you that was very helpful, do these double surface appliance boxes come cheap?:confused:
is there any specific reason you use 1.5mm 3 core and earth and not 1.0mm 3 core and earth?
They are cheap and its just our personal preference at our firm, we just don,t use 1.00 T&E, its just us.
wannabe
easiest way is to have a wireless prog roomstat, the receiver is fitted next to the boiler and the sender unit (stat ) coldest part of the house but not in a draft.
I use a 0.75 3095y flex to connect the systems.
dont forget the bonding
wannabe
Yeh good idea, but does his boiler give you that facility .
If you use a dual purpose box box,remember that most stats are now extra low voltage and shouldn't be run alongside or within a 230 volt supply enclosure
I would agree with making connections outside in a box and heat flex from there,but maybe 2 boxes
The radio stats are ok for difficult installation runs,but I prefer hard wired
Thats right Des , but the cable is mains rated and on a surface dual appliance box there is a seperater down the middle.
ive been searching for one of these dual purpose boxes or double surface appliance boxes on the internet but just cant find any.
Does anyone have a link to one for me please?:confused:
ive been searching for one of these surface dual purpose boxes or double surface appliance boxes on the internet but just cant find any.
TLC Electrical Supplies
wannabesparky,
Guest123,
