M
magpie9999
Hi people
I'm new to this and could really appreciate some advice.
I'm in the process of putting in a new kitchen and I'm adding a cooker hood.
I've already chased the wall and the socket point alongside a double socket thinking I could spur from it only to fund it has a spur already (which I believe may be running the fridge freezer)...should have checked first :(.
anyway this is the wiring layout.
what i would like to know is if its possible to run the spur from the double socket for the cooker hood and leave the fridge freezer single socket spured also???
also not sure why they never wired up the single socket alongside the cooker switch but could this be spured from the fcu running the cupboard lights???
thanks for any advice you can give.
no mate i'm not.
i'm going to get an electrician out to do the work but wanted to know if i'm screwed with the wall chasing i've already done.
no mate i'm not.
well it wont matter will it....
you will have had to strike over the chase anyway....so if a new chase is needed..so what?....
No, no and no...
You need an electrican...you cant spur from the cooker switch, so it's incorrectly wired as it is...
i wasn't planning on spuring from the cooker switch? I wanted to spur from the fcu to the single socket alongside the cooker switch as it has no wiring at all at the moment.
some other forums have suggested the 2nd spur from the double socket should be possible if to and fcu???
i'll get my brother in law to look tomorrow hes a sparky for nissan, sure he can sort it.
was that the plumbing forum?
Obviously not sparks forums then.
if your brother is a spark dont lose sleep over it.. Go to low fell drink beer and dont worry about it
Ask your electrician where he want the chases then you provide the labour for the chasing. Remember diagonal runs are not permitted unless protected by something like steel conduit earthed at both ends.
There are many other things to consider such as RCD protection so it's not "just a few bits of wire" like some folk seem to think it is.
Really.. but It saves loads of cable...... :-)
Ahhhhhh flashbacks from when a kitchen fitter did my Mother's kitchen and wired everything reverse polarity and upside down light switches and spurs. Good times good times
Cheers Geordie, at least I got some useful advice from a fellow Black and White rather than sarcastic comments.
