Why dont you want to do it? What's the alternative? Pull a new radial through for one item that doesn't even draw anything? If you tell your customer that he might refuse the job for you :D
No, My idea would be to have a fused spur off of the ring. but this would be a bit more work as the client ideally wants the unit just below the light switch. Hence why I thought some views from others might be useful. I haven't refused to do anything either, it's just a job that is coming up. Thanks for your input
OMG you would actually spur from a ring to feed something that doesnt need to plug into a socket
Easy solution. Run every single light, socket, fixed appliance et al on its own radial.
Anyone know if they make a 60 way CU that will fit in that cupboard under the stairs?
make fault finding a damn sight easier!
I wouldnt put the smokes on the lights.... gotta be independant... or its me just being picky haha
and would be on the relevant circuit
This would be ideal except it's 20ft away from where they want it. This Honeywell evo home kit is quite new, what you get is a controller that goes in say the living room from where you can control every single radiator separately, as each radiator has an RF thermostatic valve. The controller also controls a relay, again RF, which is what switches the boiler via the zone valves. The controller comes with a plug in lead but the units can be wall mounted and we want to make it tidy. The idea is that the controller doesn't go where the boiler is.
actually better on the lights , as if the breaker for smokey trips the lights go out then you know
although the smokeys do beep when power cut off
After you have done the job change the label on the cu to
"Honeywell evo home system and lights"
then it will be a
Honeywell evo home system circuit.
