Minimise inconvenience in the event of a fault
well inconvenience can be perceived differently depending who you are, and what your doing.
Rcd trips while your washing machine is on at night, turns off your alarm clock, your clothes ain't ready for work in the morning and your late. That's inconvenient.
your baby has to have his music playing to get to sleep, your 'on the job' with mummy and the power cuts, that's frustrating.
Your 83 in your house on your own, the Rcd trips, no lights no power no central heating, you fall over the coffee table and break your hip, you lie on the floor for 3 days, in agony, til you freeze to death, more than a little inconvenient. But at least the electrician saved £60 on his job, that you paid him what he asked for.
really tho, where is the harm in using 2 rcds, or in this instance 4 rcbos
Domestic, one bed flat.
1 lighting circuit, 1 ring, cooker and shower
I can see why they did it in this case, as the install is too small to practically subdivide. If RCBO's cost the same as MCB' everyone would use them, everytime. Shame really.
As a minimum Split board, sockets on rcbo and everything else on the rcd side with at least 2 spare ways
To improve on that
All RCBOs
Or as it's a bungalow you could probably divide up the light (and possibly socket) circuit easily. Maybe they have their boiler controls spured from the ring? Run a dedicated spur from the board for it (non rcd). Add an emergency light, Add fire alarms (we do this free (-materials) if it's straight forward) or install a double socket by the fuse box on it's own circuit
The basic convince upgrade possibilities are endless pending budget :smile:
The rcd was supplied with the 6 way consumer unit. I prefer rcbos but are too expensive :(
Do you think these RCBO's are too expensive?? Combine with these RCBO's with one of their CU's and you have a very reasonably priced all RCBO CU!! An all RCBO CU is the real deal, these dual RCD CU's are nothing but a compromise, and can be a bloody headache trying to find leakage faults...
TYPE B - 10kA, Consumer Units, Fuse Boards, Fuse Box, MCB, RCD from Wyeverne Electrical
Yes you can. And it is cheaper to purchase a main distribution panel with a RCD main breaker than having individual circuit RCD breakers.
bloody hell you are making that question hard work, its a switch to isolate the supply, an rcd does that so yes its fine.
Acceptable - maybe just, good practice - definitely not.
this answers the question perfectly, just winds me up when busy boddies get involved to try and answer the question better than others to prove how superior they are.
There should be minimum 2 lighting circuits and 2 ring mains in that flat using a minimum of a dual RCD board (DP main switch) (£46 complete). That wouldn't cost any more surely and fully comply.
Fully minimizing inconvenience...
