Socket and switch heights ONLY apply to new builds.
For dwellings that's true, other than if there's a material change of use of part or all the building. So (as I read it) if you turned your garage into a shop, you would definitely have to meet the 450/1200mm in your refit.
Bit more complicated for non-domestic.
Part M Section 0.1 refers.
Yes but it only applys to new builds rewires don't count ? which if you go back to first post his is a rewire.
Yes, that's correct, I was just talking generally. But even so, beware the JabberBuildingInspector my son, the pen that ticks, the nits that pick....
I think I see what's happened. You said "You don't have to do it to the regs it's only a recommendation you do it to what it says on the drawing or whoever designed the install as long as it's safe and functions well is the your main concern" and you meant just within the scope of his rewire job. Whereas I (mis?)took your meaning to be much more general.
Eek! I spent the best part of November breaking the law! Least the client was happy!
There's little point in having to conform to Part M for socket heights unless the rest of the refurb also has to comply.
And that means ramps, wheelchair width access in doors, downstairs WC, etc etc.
That don't wash with building regs and inspectors though
That may be true. But for Joe Sparky that is all an S.E.P.*
(*Somebody Else's Problem)
What sordid things you get up to in your own time is no concern of ours, please stick to discussing electrics! ;)
PS: If I put sockets 12mm from the floor I put them upside down so the plug flex sticks up and doesn't jam on the floor. On a serious note, is there any reg against this? I know its unconventional, but doesn't derate the IP rating, so why not?
