Ask your 'teacher' to explain the difference between removing the outer grey sheath of twin and earth and a double insulated single?...the answer is there isn't any, what an idiot he/she is
If it was a hazard to have single unsheathed cables in a consumer unit then everything would be wired In double insulated singles
And as pointed out you get a better termination in the main switch if you remove the grey sheath.
Also are the short lengths of Brown / blue cable which connect the N bars to the RCD's ect double insulated?.....no their not,and they are installed in a factory!
