I strip it an inch after entering the unit, you can safely isolate the Incoming tails by fitting a main switch after the meter, wait 6 weeks to get the DNO out to fit it or yank the cut out fuse and do it yourself !
well...i would never advocate pulling the bullit.....
under load...lol...:reddevil:
Nothing wrong with it at all as long it is within a enclosure, on the meter connections though I use insulation tape to identify conductors.
You should ask you lecturer why it is wrong and what regulations it breaches.
you mean the installed 100A isolator dont you :D
