G
GLENNSPARK
i dont give a ---- about this fella....To be an ignorant, harsh and abrupt electrician? Wow, you must be popular.
Why are you being so harsh and abrupt with me and calling me names? What's wrong with you?
The job i worked on is a 3 bedroom house, and the property below is a hairdressers (That is now out of business and has shutters on it) has incoming 6mm and 2.5mm cables that are live and needed to be deadened and terminated. The 2 flats below are going to be occopied in 3 weeks and the landlord of the the flats cannot get in touch with the owner of the below defunct barber shop where there supposed CU is.
You should THINK the obvious before spouting stupid comments and insults, which just shows your complete ignorance and stupidity.
i think your a chuffin dummy for wanting to work live cables....
The problem arises from time to time. I worked for EGsys for 3 years and 75% of my jobs were on live wiring. They ALL had to be cut, seperate, terminate. And all we had was PVC gloves and an insulated stanly. So you are the dummy who thinks that this is a unique problem. What the hell are you doing on this forum?
If you've not found what you want in 3 years, why ask now?
Oh, I forgot.... it's your job to be harsh and ignorant. Nothing more.
what are you doing in here more like...hit the road you plank...The problem arises from time to time. I worked for EGsys for 3 years and 75% of my jobs were on live wiring. They ALL had to be cut, seperate, terminate. And all we had was PVC gloves and an insulated stanly. So you are the dummy who thinks that this is a unique problem. What the hell are you doing on this forum?
They have been thinking the obvious, eg, you ''DON'T'' try and cut into live cables!! That not being ignorant or stupid at all!! If you couldn't gain access to isolate these cables, so be it, not your problem, come back when the client does get access!! You had no idea what protective device if any, was supplying those cables!!
It wouldn't matter if such an insulated cutting tool was available, the action of cutting across a live cable could easily deform the conductors into making contact with each other, probably sending molten copper into your face and eyes!!
So i guess the only stupid one here is yourself!! Always better to be Safe than Sorry at work!!
Using normal cutters would have deadened it!
(Potentially dangerous kids!)
