P
palmerelectrcal
Is there an RCD which will replace the main switch on an old type wylex board? the type with re- wireable fuses? (which have already been changed to compatable mcbs)
guess ill have to fit new c/u.?
argued that but customer don't want expense of new c/u. how much is seperate RCD?
Not much. Why are you wanting to RCD protect the whole installation with one device though ?
Small enclosure upfront with one rcd/rcbo covering the main board and then Pull one circuit out and into the enclosure on another rcd/rcbo for discrimination
But considering you would still have to test everything, may as well change the board(s)
want it safe but i'm not changing the board, i agree would be easier/quicker/ better etc...but the tight cust.wont pay for a new cu so he aint getting one.Hes selling up. Ill wait till he calls, when the new purchasers surveyor tell him
he changes it or they knock 2k off the asking price.
Theres outlets in the shed. and every likelyhood skt outlets in kitchen could be used
for elec equip outside.
I think it would be better just to change the cu. how would you go about separating the sockets from the lights? Ie sockets on rcd and lights unprotected? Seems abut impractical
B&Q are doing a populated 10-way MK Sentry for £80, or a BG 12-way, populated, for £50. How cheap do you want to go?
Just that nothings protected at the moment.....guess ill tell the customer "no probs coz if anyone fries cutting the hedge its his prob"..as hes too tight to pay to have the job done... :-)
But you will probably open a can of worms putting an RCD on an old installation if its not to good. For what you will earn from a small job like that I would walk away
