L
LushMonkey
I'm working on some buried conduit and it is frozen. Have managed to break free some of the ice, now there is suction at other end when using a vacume. However I cannot get a bag or a fish tape through all the way gets hung up part way through. I have tried antifreeze was wondering if anyone has any suggestions other than digging them up?
Is the conduit 4 inches in diameter or is it buried 4 inches deep? How long is it and do you know how much of its length is frozen?
Edmonton AB, Canada. Four inch pipe buried a good six feet down. Its for the service coming off the transformer to switchgear. Gonna try a Herman Nelson blow some hot air down um and suck on the other end with the vacume. Hopefully the hot air flowing will melt it away
Ah that explains a lot. I think your method will work as long as some air can pass through the pipe. If the ice has made a completely solid plug then I fear you may be SOL.
you'll probably want to pump melt-water out. If you blow warm air through a pipe into the duct, run a tube within that to stop it freezing on it's way out. Is the duct cable free at present?
So a pretty big conduit, and it's at quite a depth too, more like a duct in fact. Either way perhaps this time when you have finished and blown/pumped out any standing water, you'll duct seal the ends up... lol!!
last time i used conduit that size had to use CHICO A & CHICO X to seal them but that was for bio.hazardous install
Any electrical ducting that goes underground should have a duct sealing system applied...
No its nothing like a duct, its four inch PVC conduit. They have bell ends and you use PVC glue to close the ends. It pretty much melts the pipes together. You use this when you need to run pipes underground. But hey can't say I've ever seen an engineer running pipe
There not for bio hazard, installing a 600 amp 208 service running two parallel 300kcmil feeds from transformer
only stated that we used it for a bio. job and it was 4in steel conduit from weatland (usa) 4in plastic in uk is called a duct
