buried boxes | on ElectriciansForums
Discuss buried boxes in the UK Electrical Forum area at ElectriciansForums.net
wrighty
leeds
evening all,
im after a few pointers, could somebody suggest a decent box that can be buried under ground, im looking to install some bollard type fittings in the back garden on top of flags. im thinking of SWA in and out, flex up through flag into bollard.
cheers
I did type a lovely reply, but the forum did it's usual trick of timing out on me, so I'm not typing it all again...
One word..Hi-tuff
I'd agree, Hi-tuff is good for this application if unlikely to be mechanically damaged. I'd try to get all the terminations above ground if at all possible, even if that means choosing a different bollard light.
Here's a job I did recently using swa glanded into 20mm trouser boxes
[ElectriciansForums.net] buried boxes
Then bollard bolted on top
Reply to buried boxes in the UK Electrical Forum area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Recommended Sponsor News
Hi everyone,
