M
marksparks
Hi just inherited a second fix job, it has a heatrae sadia amptec electric bolier fitted rated at 10-12kw ready for wiring there has been a 10mm t&e cable installed to a double recessed box by the boiler. It also has an electric shower fitted so i need to install the RL1 relay from heatrae sadia so they both dont come on together, the mcb in the consumer unit is 50amp the questions i have are as follows -
1 - do i need 10mm heat resitant flex in to the boiler?
2 - who makes 50amp 2gang double pole switches?
3 - should i use a small con unit on the 10mm to split thing up
4 - can i take the feed for the programmer and control of the boiler feed obviously fused down or take the controls feed from an adjacent socket which would mean two seperate supplies on to boiler
any help if you have installed one apprieciated.
