Discuss 12v LED tape recommendations please? in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
After a recommendation for decent cuttable LED tape, have been using enlite weatherproof (Can't remember where I bought my last reel?) but it has been a pain to join, looking for a tape and supplier, prefer 12v.
I've found Enlite to always be good products, well designed, well made, reliable, efficient, good power factor etc. I'd stick wth them unless you know for sure the alternative is equally good.
They do have a range of connectors available for their LED strip lights, is it those connectors you're having problems with?
Last time I bought an enlite strip strip it had a gel on the front (ip65) had to scrape that off to get the connector on (was very hit and miss) and then couldn't get the connector into the aluminium profile. Would now buy non waterproof so suppose I could just invest in a dremel to adapt the connector or solder it!?
Reply to 12v LED tape recommendations please? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
