C
Chrisknowlesuk
I would like some advice please.
A friend of mine has moved into a small flat. There is no Gas supply to the property and so is looking into having a 14Kw Boiler installed. This would require a 63A breaker on the board. My calculations for Maximum Demand based on the other circuits in the property comes to approx 95A.
She has no access to the meter as it is situated in the neighbours flat across the hallway - they are currently away travelling. Although, based on the probable age of the flat I would expect it only has a 60 or 80Amp fuse on the supply. And would therefore need upgrading.
Since this will present a whole load of issues I just wanted to make sure I am thinking along the right tracks and if anyone had any good ideas please??
Chris
Chris
