Discuss 16 A Commando Combination Unit Required in the UK Electrical Forum area at ElectriciansForums.net
Evening Gents,
I have been tasked with running a 240v supply to a small diesel storage facility. I am looking for a combination unit which would consist of a Main switch 30ma RCD 16amp mcb and an commando socket outlet to supply a .3kw pump. Does any such thing exist out there.
Cheers
Sparky
MK Commando Interlocked Angled Socket 2P+E 16A RCD 200-250V (IP44) | 240V Industrial Range | NoLinkingToThis
Now that's what I call service!!
thanks mate , the unit will be fitted outside so i think it will need a higher IP rating, the added issue is i need to have a standard 13amp socketbuilt into the unit as i need to plug a reciever into the unit to highlight oil level alarms
Denmans do a nice unit for around 50 quid, they are IPX 65 and great to install.
Have a look through the Lewdens range, there's LOADS of options available. Better still, tell your wholesaler what you need and let them find it!
Reply to 16 A Commando Combination Unit Required in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Sorry if this is obvious but I thought discrimination was for down stream? I want to feed and outdoor unit which only requires 6am and 16amp, it...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
