Discuss 18th edition question in the UK Electrical Forum area at ElectriciansForums.net
Watch the videos by John Ward and SparkyNinja who explain all the changes in the 18th edition.
Never experienced fallen cables that hindered me in a house fire, nor the melting of plastic rawl plugs causing items to fall.
521.10.202 is a very significant change which will require consideration to achieve compliance. I predict there will be an awful lot of non-compliant new builds and extensions during 2019, because many will just carry on as they always have.
Hum ......... so in a finished domestic premises how would anyone know or check this?
Serious question BTW
Little is done now to check any existing BS 7671 compliance - so why focus in on this?
being a tight fist, i not got 18th book.can you paste that reg?
There’s not many instances where a new build would be effected by this other than if trunking is used to house the cables to the DB or any detached garages with surface conduit drops for accessories inside.
Are you suggesting you will ignore this regulation?
521.10.202
Wiring systems shall be supported such that they will not be liable to premature collapse in the event of a fire.
This is a blanket requirement, no distinction is given to areas of wiring or type of installation. I have been informed that a plasterboard ceiling is not considered to provide support for cables in the event of a fire, and that all wiring throughout its length will require support with (for example) steel straps, unless it is drawn through joist holes.
This will have implications for rewires where cables are often fished through areas where floors are difficult or impractical to lift for access.
New posts
Reply to 18th edition question in the UK Electrical Forum area at ElectriciansForums.net
I am currently going self employed. I was never put through any 18th edition courses, so have booked myself onto my 18th wiring regs. I want...
Hi All, Im looking for some information for electrical improvers working abroad. Im currently self funding my way through my electrical course as...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hi I’ve recenly completed my apprenticeship, I come into a conversation with many people that give me 2 answers 1 that I’m up to date with the...
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
