Discuss 19.4kw cooker......... in the UK Electrical Forum area at ElectriciansForums.net
They'll have a "must be installed by a competent electrician to relevant regs" or something to that effect in there as well to cover themselves. Just find it daft they have stated cable size
I agree .............. but when did you last see any manufacturers instructions that gave out decent constructive advice?
FWIW I installed 10mm, even though it wasn't passing through any insulation!
If it is going in a domestic kitchen, with diversity applied a 40A supply should be fine. If my calculations are correct.
Some years back a mate called after Christmas to say his oven had tripped several times severely disrupting the prep of Xmas dinner. It had been installed following extensive refurbishment by the builders sparks on a 40a mcb and if I recall was a similar rating and model to this one. Since upping the mcb to 50a there have been no further oven related Christmas dramas, OP take note.
Just wondering what size cable been installed to change the ocpd to 50amp, bearing in mind the usual installation method in a domestic property?
Reply to 19.4kw cooker......... in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
