I have a 2 gang dimmer switch which work both lights in the room ok (a main and a side light) The other switch has never worked properly only switching the main light on, but won’t switch off the light when dimmer is on, it just gives the full power to it. In the switch there are 3 wires, a red, a yellow with red sleeve, and a blue. Does this mean that the switch has never worked 2 lights? How do I wire the switch, so that it switches off when the dimmer is on? Any help appreciated, thanks
Can you get pics of the wiring behind the switch? Is that all there is? Red/yellow/blue?
Also in the pic, the terminals of the switches and what is connected where.
Is there a short link between the two switches?
Can you confirm this is the only switch for the room? (Ie it’s not a 2 way circuit)
What is it you are trying to achieve with the switches?
Ie one switch for the ceiling light, one for the wall, or just one switch for both lights?
Thank you so much for your reply. I will take pictures of each switch. One is a two gang dimmer which I have wired and seems to be working fine. It works the main ceiling light, and a wall light. The other 2 gang switch has never worked properly since we moved in. If the main ceiling light is on at the dimmer, the other switch will not switch it off. You could switch the main light on from there, but you cannot switch it off if dimmer is on. I will take some pics and get back to you, and thanks for your help
Dimmer at different angles so you can see where each wire goes. The single picture is the switch at the other side of the room. I don’t think it can work both lights as there are not enough wires, but if the main light could be turned off when leaving the room at that side, it would be good. Otherwise we will have to keep walking over and switching off!26C54415-7438-4AA0-BAFC-6C53C7709A95.jpegF37B3C81-EB88-4CE0-8E58-CEEF731494C3.jpegE259F808-8746-4081-965A-36F03F8B0C4C.jpeg7AE4E564-D1C8-47EC-943B-1153FFCF166B.jpeg
nbot sure but think maybe 1 or 2 of the reds in pic 3 should be in L1 instead of common.
Those connections in the bottom pic must be incorrect.
A swag from me would be (bottom pic) to move red to L1 and yellow sleeved red to L3. But I would test before changing anything. I have seen a number of these setups that have been "adapted" over time to account for failures in the switches. At least there are some pics now to refer back to :) .
I think here is an error in both switches.
The red and blue in pic 4 definitely need separating, but in the other pics, it appears that the non dimming switch has both sleeves blues going into it, when one should be going into the dimmer. It appears there are two, two-way switches there, but seem to have got muddled up
without belling the cables it'strial and error.
1. it works
2. it don't work
3. bang.
Both of the connectors in the first 3 pics are dimmers. It a double dimmer switch. At the moment it works and dims both lights. So you think the two blues going in together shouldn’t be? Any idea where I should move one of them to? Sorry to be a pain.
Hereford
Business Name
None
2 Gang Double Switch Problem
DIY Electrical Advice
Juney,
Juney,
