Would that just require a switch wire from each light to the fan?
I've read about relays being installed.
Yes. A relay where either switch line will pull in a common switch but remain separate from one another or you will get the switch in the toilet switching the light in the shower and vice verser.
or one of these .
The vents would look lovely
Eh? Where did that come from?
the genuine russian version of the hat above
Don't forget if you are running from a hot space to a cold space use insulated duct work or you could cause condensation in the pipe work leading to mold issues.
Even rigid pipe should be insulated, also depending on your run & angles you may even need a condensate trap in the pipe run.
All things to weigh up.
Good luck
Was looking at those yesterday.
As inline fans are mounted in the loft, I'm assuming they can be fitted in any zone of a bathroom and only require the basic IP rating?
If they are in the loft they are not in the bathroom.
Noob2013,
Essex_,
