Discuss 2 inline extract fans in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
Just after a bit of advice.
I have split my bathroom into two so I now have a bathroom and shower room next to each other.
I would like to fit an extract fan in each room but only with one hole to vent outside.
What's the best option?
Would I need 2 extract fans joined with ducting and some inline shutters so prevent backdraft?
Could go from each room into a tee then duct to the fan. It would reduce the extract rate of the fan in each room so would need a good inline fan at the very least.
What's the issue with having a second hole?
Hi
you can run 2 bathrooms off the airflow inline fan put the branch before the fan only problem you have now is the switching unless you are happy to turn on both lights at same time, unless you put in small relay to stop that.
If fan is before the branch then it will extract from both rooms at same time can balance the shower ducts with vein Ommieter (hope I spelt that right) meter & then this will ensure they will extract at same rate.
Yeah its in my own house.
2 holes isn't practical due to ladder position restrictions but could be done if required.
Just after easiest option :)
I've also read that it needs to be pretty powerful for 2 rooms.
Any idea on the rate required for 2 rooms?
Tee is not as good as a "Y" from a smooth airflow point of view.
You can use 2 fans into a common discharge duct but you should go up at least one duct size after the point they join and you would need inline shutters on both rooms. You can also go with a common fan for both rooms but the wiring can get a bit tricky depending on existing layout and you'd need an adjustable diffuser in at least one of the rooms to give you some adjustment on the air balance. The room with the shower I'd be working on at least 20 room volume changes per hour and probably 15 changes on the other room.
or one of these .
The vents would look lovely
Why don't you fit 1 in-line fan in the loft and just put vents in the two rooms. Wire it so either light turns on the fan. Plus the extract will be very good.
Would that just require a switch wire from each light to the fan?
I've read about relays being installed.
Yes. A relay where either switch line will pull in a common switch but remain separate from one another or you will get the switch in the toilet switching the light in the shower and vice verser.
One of these Circular 'Y' Piece White 100mm | 100mm Ducting | NoLinkingToThis and two of these Manrose In-Line Centrifugal Shower Fan Kit Chrome 100mm | Shower Fan Kits | NoLinkingToThis they have built in shutters - fitted loads with no complaints!
Was looking at those yesterday.
As inline fans are mounted in the loft, I'm assuming they can be fitted in any zone of a bathroom and only require the basic IP rating?
Don't forget if you are running from a hot space to a cold space use insulated duct work or you could cause condensation in the pipe work leading to mold issues.
Even rigid pipe should be insulated, also depending on your run & angles you may even need a condensate trap in the pipe run.
All things to weigh up.
Good luck
Reply to 2 inline extract fans in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
i have a toilet compartment and a separate adjacent shower room and i am fitting one remote extract fan, via a Y splitter to ventilate both rooms...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
