R rugbylad ~ Mar 14, 2017 #16 westward10 said: Loop between line and neutral to check your meter. Put one lead to line and the other two to neutral. Click to expand... I'll give it a try in the morning
R rugbylad ~ Mar 14, 2017 #17 SparkyChick said: Do the leads to your tester work OK and report properly on say continuity? Does it have a fuse that could have blown? Do you have a reference circuit you can test against (I use a ring main at home and my CalCard for checking things like this)? Click to expand... Well I did seem to be getting low readings on my r1+r2 tests, reference circuit at home is a cracking idea, I'll use that moving forward though
M Mav_2014 Nov 4, 2017 #18 Zero leads and insulation and continuity every time you swap them. If it's still not reading right it's either a calibration adjustment or repair. Anyone else have these issues send them over!
