Discuss 2002 Toyota Coaster - brake warning light in the Auto Electrician Forum area at ElectriciansForums.net
Hi all you guys out there. i have a Toyota Coaster converted to a motorhome and I love it however I have an issue with brake warning light not extinguishing. From what I understand ,and after looking at the schematic, the lamp is on when either the hand brake is applied or brake fluid level is low and neither is the case. I have also checked fluid level sensor and both sets of contacts under handbrake but warning lamp still stays on. Hoping that someone may be able to assist. I am an electrical contractor but not autoelec.
Reply to 2002 Toyota Coaster - brake warning light in the Auto Electrician Forum area at ElectriciansForums.net
Hello,
I need detailed assistance badly. I am trying to connect a Brake Light Module or a "Flasher" to my brake lights for attention but I want...
Hi guys!
Hoping you can help me.
I'm making a custom 12v motorcycle brake light. I'm at the stage where I need an LED board/unit that does both...
Hi All,
I'm a working man relying on his van to stay in business - but of course it's developed a horrible electrical fault that needs more...
Hi,
I've just joined the forum and hoping someone can help with what I am looking for.
I'm looking to design a circuit for my bicycle that will...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
