A
aaelectric
I have looked at this pdf and it doesnt say much, so there is no way this should be used?
also why would it give you the mad readings from being off and powering up, what is vov?
what is the floating earth
) that has no other incoming supply, they can be perfectly safe if the earthing is correctly installed. The bottom line is they're best just used for portable power with a trailing cable which is what they were designed for.
