darran2020
Hi All,
First post on here, was just wondering if anyone had any hints or tips r he 2394, 2395 written exam , am very nervous, I walked through the both practical's and multi choice but am proper bricking this one
cheers
Darran
Reactions: 1 person
Welcome to the forum.
Do not panic!
If the practical and multi guess were easy then this should not be too bad.
So long as you remember the correct wording to use and have been revising GN3 then you should be OK.
The chief examiners reports available from the city and guilds website under additional documents gives pointers on where candidates have dropped marks so if you brush up on those areas this will help avoid common mistakes.
Plan your approach to the exam and if you cannot easily do a question miss it out and do others and come back to that once you have gone through once.
Read the number of marks available so that you can assess the number of points you need to make.
A one mark question will need a short phrase in answer.
Good luck.
darran2020,
darran2020,
