Discuss 24v DC electric roller blind in the UK Electrical Forum area at ElectriciansForums.net
Kris83
Hi everyone,
I'm a total novice, so apologies if this all sounds obvious & easy!!!
I'm wanting to install a motor to my roller blind & have found a 24v motor kit on amazon.
Issue is it only comes with 2 bare wires from motor & needs wiring to plug into a 24v ac adaptor.
Tried looking online but can't find a thing.
My questions are:
1) Can I use a 24v ac dc adapter like the ones used for christmas tree lights
2) Will the wire (picture attached) be suitable to connect to blind & plug into adapter?
Pics of blind, wire & adapter attached.
Welcome to the forum.
The roller blind will have a power rating for it. You must make sure that the 24v adapter is DC and not AC, as the title says the roller blind is DC. Also that the power rating of the roller blind is big enough to do the roller blind.
Your Amazon link just takes me to the Amazon site so I can't check the roller blind.
[automerge]1573083768[/automerge]
Just a correction for the above. Make sure the power rating of the adaptor is big enough to do the roller blind.
The link is not working again mate.
I will see if I can find it and see what info there.
We need to know what power rating the motor is so that you get the right size adaptor.
Also need to know what is the power connector to the motor like.
Found it.
In one of the pictures the adaptor is wired up to the blind.
It looks like the blue/white cable is the positive supply and the white cable is the 0V
Also in one of the reviews it says the motor takes less than 1A.
I would try and find a 24V DC adaptor that is 1.5A, to be on the safe side.
Hi,so it is 24v dc...the least you will need,is the power of the blind motor,to size your transformer.
Is it remote control? If so,you will need the tranny,pluggeg in 24/7,so it needs to be rated for 100% stand-by.
I will be honest....some of the available transformers from across the water,are not of a standard,where i would be happy leaving them on,full time,in my property.
Reply to 24v DC electric roller blind in the UK Electrical Forum area at ElectriciansForums.net
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
Hi everyone, I'm looking to do some cable runs for cat6 etc in my house and was looking for some advice on blind wiring. I'm not skilled but I...
Purchased a Panasonic VL-SWD275 video intercom from Australia to replace my 2-wire intercom in the US. The Panasonic VL-SWD275 requires 220v and...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
