Discuss 255V measured instead of 240V in the UK Electrical Forum area at ElectriciansForums.net
Hello while 255V seems to be a normal voltage for low voltage networks it causes issues to my solar installation where the inverter works up to 240V.
Any idea why Western Power increased the voltage?
I have 48V energy storage. The inverter inverts from 48 to 240V ac but at 255V can not push any power out of the batteries. It is a grid tie system with energy storage
Report it, they will send someone out to check and investigate as it is over (slightly) the max permissable.
They are having big problems keeping the voltages down within the 216-253V window due to microgeneration so I have been told
Have you monitored the voltage at different times throughout the day, what time of the day was the reading you give taken
The voltage will usually fluctuate throughout the day and at peak load periods will drop to a level at or just below 240v
Reply to 255V measured instead of 240V in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
