Hi - if I may, I’d like to start with a question - why did you get 3 reports?
Tester 3 seems to be measuring somewhat different to they other two for the highlighted circuit so unless that circuit has been altered his/her readings indicate the circuit is now much shorter than previously.
Thank-you every one who respondedWe have three sets of readings for the same circuit, two are similar so we can assume they are correct. If we assume these are correct and the circuit has not been altered then Tester 3 is incorrect, the readings are way off the first two.
Think, Mad as a fish?what made you get 2 more?
The first report is from 2013, I guess the second recent one is due to lettings legislation, and the third because the second one gave the wrong observations (C2 instead of C3 for the usual items).
No replies ???Gent's
Before I send tester 3 a revised table (attached) highlighting down stairs ring-main anomaly, would you mind doing a sanity check on the document to ensure there are no glaring mistakes.
Much appreciated,
