Discuss 3 phase supply in the Commercial Electrical Advice area at ElectriciansForums.net
Next month i will be working on a farm putting a new 3phase board in to supply welders, plasma cutters etc. 3 phase comes into electric shed (Tnc-s) and then supply into barn comes from 80A 3ph MCB with a 300 ma trip upfront. Supply enters barn and goes into an existing board with the earth path separated and spiked down, i will be putting a 63A 3ph supply to new board clipped direct internally in SWA, do i need to protect this supply cable with a 100ma rcd or can i just feed it with an MCB?
Cheers in advance
Reply to 3 phase supply in the Commercial Electrical Advice area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
Hi, we are converting old farm buildings to commercial units, and as my father used to run a vacuum pump and compressor in his dairy I always...
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
