I am having to upgrade the supply due to moving the underground wires and have a few questions.
I did have a conversation with my inspector and got the basics but trying to keep things moving over the weekend. The house has overhead lines running to a pole and then on that pole there is a 200A breaker, then a junction box, 140ft of 4/0 4/0 2/0 wire that runs from here to the house panel. I know I need to run another 4/0 wire as the neutral but can I then bond the ground and neutral at the junction box or does it need to be in the breaker box. And if in the breaker box can I just run the 2/0 wire through the junction box and to the ground screw in the breaker box or do I need to upgrade the breaker and junction box as well? Only reason to have the junction box is wires running to a shed from it. Pictures below, let me know what other information is helpful.
