J
jacks
Hi
I'm a mobile caterer and my unit has a 16 amp cee form inlet.
A lot of events supply a 32 amp cee form supply.
My question is if i get a 32 amp to 2 x 16 amp such as this
with RCD on both arms will this work. I have a support kitchen to the rear of the unit so would feed one 16 amp to the mobile unit and one to the kitchen at the rear.
Obviously i would keep each 16 amp arm to less than 3680 watts so not overloading the arms.
I've seen mentioned the 'widow maker' and hope this doesn't apply as these splitters are readily available with 2 x RCDs and assume these would trip out before any over heating?
Many thanks in advance.
