Discuss 3kW Immersion Heater in the UK Electrical Forum area at ElectriciansForums.net
Thanks for your reply. Yeah I discovered that the maximum setting was a thing, went back to CEF and asked for one with no maximum, and they said they could supply one with 80C max setting. As you can see it has 80C printed on the side; thermostat1 — Postimage.org - https://postimg.org/image/m16zv8njl/
Unfortunately it still did not reach that temperature.
Have a check of that, their web site suggests it's set to a max of 60'c, couldn't see anything else? Is the 80'c for the safety cut-out?
RDT resettable thermostats - Easy Fit thermostats - https://www.heatraesadia.com/products/cylinders-and-hot-water/immersion-heaters-and-thermostats/thermostats.htm
daptable boxes with din rail
Problem solved then
Not really. As mentioned multiple times before, when the old thermostat is in although it reaches the required temperature, it makes a popping noise which really doesn't sound too good. So, change thermostat. Now the popping noise is gone, heater still 'works' but it does not reach the required temperature.
So clearly, the heater has the potential to reach the required temperature, but for some reason with one thermostat it makes it, but with another it does not.
I don't know. I went into CEF and said 'this thermostat doesn't heat the water up to the temperature I need it to', so they gave me this other thermostat that apparently would allow the water to go up to 80C. It doesn't.
soz. pete. dunno where that link gotinto it. i bame that dr.altzeimer. we never used to have dementia till he came along spouting his theories.
so. OP has a thermostat thap goes pop. obviously not genuine kellogs as it should go snap, crackle first.
I'm off to the cancer Docs tomoz for a check up, He's a Proff so should know his stuff, seriously a very nice Man.
Reply to 3kW Immersion Heater in the UK Electrical Forum area at ElectriciansForums.net
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I have a customer who has an 18" thermostat in their water tank which periodically requires resetting. I went to replace this but am unable to put...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
