Discuss 3p Tpn converted to Sp in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In this case both the L & N of the supply are carrying all of the load, so design-wise it should have upstream OCPD that is rated for that cable (as I suspect the sum of downstream MCBs is way higher).
It may have DP isolation but not at that location.
The neutral will only require switchable isolation in say a dwelling. Commercially the neutral requires a link to disconnect it
For that board no it just links the three lines. I believe the new Eaton ones become a double pole switch which also switches the neutral.
I know that I would fit a DP main switch, never seen a single phase supply without one.
Its a EICR so it’s been in place for some time, classification code C3 maybe after reading all these messages ?
Explain why it needs Coding.
Reply to 3p Tpn converted to Sp in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi I always thought installations were safe at the time of instalment etc, the Distribution Boards at my works were installed over ten years back...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
