Discuss 3phase 32amp socket swap for 16amp in the UK Electrical Forum area at ElectriciansForums.net
will_505
Hi there, I've got a 3 phase compressor and a small 8500W single and 3 phase generator. My compressor has a large 32amp plug on it but my generator only has a 16amp socket so my question being can I swap the 32amp plug to a 16amp plug?
Sorry if this is a daft question.
Thanks guys 🙂
It is likely the compressor needs more than 16A and you might find the compressor simply stalls the generator when it kicks in. To have a better idea you would need to provide more details of the compressor and the generator.
you can change the plug, however if the compressor is more than 8Kw it will definitely overload the generator, even if it is below that, it might struggle to start.
Reply to 3phase 32amp socket swap for 16amp in the UK Electrical Forum area at ElectriciansForums.net
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi I have a 3phase shop in a high humidity area in (Hawaii) and I'm having some issues with low voltage on the single phase outlets on the 120v...
