Ordinary single phase bench grinders have PSC induction motors which are almost impossible to control by phase angle 'dimmer' type controls such as you have there. It would control a universal (series) brush motor fine, but probably not the grinder motor. I expect the chopped waveform is causing huge peak currents through the capacitor winding, tripping the MCB. There is probably nothing wrong with either the motor or the controller, they are just incompatible.
About the most you can do with phase angle control on induction motors is little shaded pole motors like fans that have nice steady load. Even with the best method of voltage control, a Variac, you can only drop the speed of a single phase induction motor by perhaps 10% before it loses all its torque and stalls. That is why inverter drives are so popular, because they are the only way to do the job.
E2A oops did not see DW's post, yes could also be split phase and the same problem will apply
