Discuss 400V & 110V in same Junction Box? in the Electrical Engineering Chat area at ElectriciansForums.net
Hi,
I am a design engineer (2 years out of apprenticeship).
I am in the process of amending some designs that are not quite to our company standards.
There is currently a junction box that houses a 400V supply and a 110V supply with no segregation of the DIN rail terminals. This doesnt seem ok to me.
Is it ok to have this set up or should I make the attempt to segregate the two supplies within the junction box panel?
Note: I would have preferred two separate junction boxes but this is not quite an option at this moment.
I am in the UK.
So long as the insulation factor of all of them is to the highest voltage present and everything is clearly labelled (is it actually 110v or is it 55v CTE?) then I don't believe there's an issue. However, I'm in agreement that it's not a great way forward - why not just use a couple of spacer blocks inbetween?
Sometimes I put in an G/Y earth block between such sections even if not needed. Provides a little more reassurance!
You can also get separator sheets for many DIN rial devices, or another option is to use different colours to identify different voltages.
But simplest option if enough space is to use a couple of end-stops and make it like two blocks on the same rail.
If either of the supplies is electrically separate, then more than basic insulation is required between them. If not then as mentioned it's technically acceptable but IMO poor practice. At the very least I tend to put an end cover on the open side of the terminal to double-up the insulation, but space permitting an earth terminal or endstop is better.
Historically in theatre lighting we often had to deal with what one might call 'installed multiple extension leads' where dozens of circuits ran between plugs in one location and sockets in another. When any plug isn't engaged in a socket its pins are exposed to the touch, so its circuit conductors need to be suitably insulated from those of the next circuit which might be energised. Within the cables each has its own insulation but when they are all terminated to DIN terminals on a rail, there's only one layer of insulation between the metal parts of one terminal and the next. DIN terminals were not the only situation where this inter-circuit insulation was marginal (19-pin connectors were another) and everyone did it, but it was a frequent topic of conversation.
Reply to 400V & 110V in same Junction Box? in the Electrical Engineering Chat area at ElectriciansForums.net
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
Hi, I have taken over a design engineering job for industry. The design is using a 400V/110V transformer. Usually, the 110V is single phase...
4K
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
We are renovating our kitchen, and part of the renovation involves replacing our gas oven with an induction stovetop built into the counter and a...
