The original question was is there a small 63A isolator?
The answer is no, because they are not required and the physical size would be large to accommodate the contact size.
Perhaps there is an alternative.. see the previous 105 posts.
Morning I mention induction because someone seemed surprised by the size so was explaining why there so big.
I am installing 10mm so that she can have what ever cooker she wants (takes ages for her to make her mind up) therefore going through a 63A isolator and the mcb be will be any thing between 32A to 63A. Covering all bases.
I agree that it will never pull total load so diversity isn't a problem, to get to total load you would have to have everything on full whack and god knows what you'd be cooking for that.
I've enjoyed this thread very interesting but know one every answer the original question.
You're having a laugh now, .....Aren't you??
Yes but we're not designing a circuit.
We're working out how many amps is 17kW @240V which is what the manufacturer will have stated.
At 230V it will be less, not more.
CU the other side of the wall cable length minimal no thermal insulation run inside plastic conduit into CU 10mm will cover 63A
It's NEVER going to see 63A!!!! You're talking about a cooker load, that is just 2 KW over and above, that can safely be supplied by a 6mm cable on a 32A MCB/RCBO!! ....So you have just got to be having a laugh with us, if to cater for that extra 2KW you're going to ditch the 45A CCU for a 63A isolator, that is going to be one hell of an ugly so and so, for a domestic kitchen.
Just wait until your customer see's the size of it!! lol!!
Thats why I sad about using a main switch as the local isolator in the cupboard the enclosure is about 125mm high by 75mm. As she's never going to see it I don't think she will be bothered.
as for the 10mm I am covering my arse just in case she turns up with the monster 17kw jobby.
As for the emergency stop button I have found a nice polished chrome one so I think that will work quite well. :smilielol5:
That's right they induce the heat into the cooking utensil/pan, not the surrounding glass or element. These hobs are so fast, that they can cook a fried egg to perfection before a conventional halogen hob has even started to turn the egg white, White!! They do hit max quite often, but are still subject to thermostatic control. Just everything happens that much faster!! lol!!
I'd never swop back to a gas hob now. Never had an electric hob, they were and still are totally uncontrollable, and remain hot enough to burn you for a good hour or so, after you have finished cooking. ...total waste of energy!!
Cheers cock, I thought so.
I've seen a picture of half a frying pan on an indy hob with an egg cracked on it, the bit on the pan is cooked and the bit on the hob itself is still raw. Excellent! I'll be definitely be getting one on the next kitchen upgrade.
God help your customer is all i can say!! You haven't got a bloody clue what you're doing!!
The other great thing about these hob's, is that the glass surfaces don't get hot, so no burnt on spills or splashes, just a quick wipe and it's all clean again...lol!!
