Good morning,
We have a load of approximately 18.5kw ( compressor skid). There is a plan to install a dedicated socket for this machine, the cable route is yet to be finalised and One of the contractors says 16mm2 cable 100A fuse is adequate but this comes from a rule of thumb as opposed to calculation. Is this a common rule for 63A sockets ?
There isnt really a "common rule" it is entirely dependant upon cable length, installation method/route, size & type of protective device, ambient temps etc etc.
Get it designed properly then come back :)
without knowing the length of the run, i'd say 16mm cable on a 63A breaker is closer to the mark. i assume it's 3 phase. that equates to around 30A per phase.
You have to base the supply on the socket outlet because it could be used for any purpose.
Anywhere
Electrical Engineer (Qualified)
63A three phase socket
Lc1,
Deleted member 26818,
