L
ldworks
Hi all,
I have just started with a new company and have been asked to wire in a oven and hob but the hob will have an addition flex out added next to existing cooker flex outlet. The wattage is 10.5kw and the manager is saying its fine to just wire it up but I feel that this wattage is way to near the recommended amount of amps to what the cable can handle. Can anyone quickly state a reg that would help me?I work on council properties and I personally will not wire a for instance a 8.5kw shower in 6mm as I've got it into my head it has to be 10mm but can't remember where??HELP PLEASE.
Try looking at table 1A and and 1B appendix 1 in the osg mate....
I have my own 8.5KW shower on a 6mm and that is all its getting
You have taken a firm position on this and yet also state you dont know why,I'm puzzled by the comments
Hi all,
I suggest you look at the numerous other threads on this forum that directly relate to your query and questions!!!
Then come back and tell us what you have learned from them...
Can someone please explain how some people can call themselves "Electrician", all "Electricians" i know can calculate volt drop/apply diversity etcc.. I.e Just like a "Hairdresser" cuts hair
The 10mm theory more than likely comes from the council/associations you work for, they like to overcook the situation/futureproof it, as long as the correct sized MCB is installed what have you got to worry about? Let it trip, you'll get payed for going back and changing it
Well I believe I learnt it as a good code of practise and personally makes sense but want written knowledge but may have to go back to osg. When working on council they will not allow a 6mm cable on anything over7.5kw and 10mm for everything else.job I'm being Asked to do is the wattage added up for both hob and oven add up to 10500watts (10.5kw) and I. Want to instal
A new circuit of 10mm to run both units.
When reading this, look a bit further down the page to the section entitled "Similar Threads", I'm sure you'll find a wealth of knowledge in there ;)
Hmm Vernam, 361 posts and not one thanks, wonder why........!!!yes I know about diversity but purely wondered if it was stated n e where!!! Master at arms-master of being a arrogant ****.everyone else thank u.
osg say 6mm 32amp mcb for domestic cookers ect >15kw, it has been used for years now and ive never had any problems myself as well
Well I believe I learnt it as a good code of practise and personally makes sense but want written knowledge but may have to go back to osg. When working on council they will not allow a 6mm cable on anything over7.5kw and 10mm for everything else.job I'm being Asked to do is the wattage added up for both hob and oven add up to 10500watts (10.5kw) and i Want to install A new circuit of 10mm to run both units.
Then your a fool!! Look at the cooker diversity formula in the Reg's. That formula is good to ''15 KW''!! That Reg is and has been good for around 60+ years now!! So what makes you think, that you know better???
Haha you really are stupid, that thanks is for the amount of times I HAVE thanked people, look a little further below that 23 times in 21 posts
Get back to college and stop fobbing people off by calling yourself an electrician, how imcompetant to come onto here and embarrass yourself with such a question, had it been a DIY/homeowner id have answered it for them, but definatly not for a so called "Electrician"
