Discuss 6MM OR 10MM in the UK Electrical Forum area at ElectriciansForums.net
Norm2001
Hi All,
I am making a annex in a old workshop about 35 metres away from the main fuse board.
It will have a water heater for a shower and sink and then just a few sockets for a kettle etc.
Would a 6mm cable be sufficient and what size shower rating would I need?
Thanks for any advice.
If you are talking a power shower which heats the water & a water heater as well then you are looking a quite a big load.
you need to find out the wattage of your preferred water heater and power shower before you can work out the cable you need.
you need a spark to work out and calculate the full load and part p the work to your LBC.
As already said, you need to make a list of what you want to have, and also think of what you might want to add later. While cable is not cheap, replacing it later because of an underestimate is a whole lot more expensive!
Hi All,
If you want a proper job.....listen to buzz. (Spot on, pal)
Reply to 6MM OR 10MM in the UK Electrical Forum area at ElectriciansForums.net
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
hi. would appreciate advice from any electricians. am trying to replace a 13amp [35 year old MK] wall socket but the terminal cage in all the...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
