N
Norm2001
Hi All,
I am making a annex in a old workshop about 35 metres away from the main fuse board.
It will have a water heater for a shower and sink and then just a few sockets for a kettle etc.
Would a 6mm cable be sufficient and what size shower rating would I need?
Thanks for any advice.
If you are talking a power shower which heats the water & a water heater as well then you are looking a quite a big load.
you need to find out the wattage of your preferred water heater and power shower before you can work out the cable you need.
you need a spark to work out and calculate the full load and part p the work to your LBC.
As already said, you need to make a list of what you want to have, and also think of what you might want to add later. While cable is not cheap, replacing it later because of an underestimate is a whole lot more expensive!
Reactions: Norm2001
Hi All,
If you want a proper job.....listen to buzz. (Spot on, pal)
listen to buzz.
why??? nobody else does. :sunglasses: :sunglasses:
Reactions: Megawatt
I’m always listening to Buzz.... but I think it’s tinnitus o_O
  • Funny
Reactions: Spoon and ipf
Reactions: telectrix
No scouse lingo!!
toos tired at mo, but here's some stokie fer ye.
cost kik a bo agin a wo an yed it till it bosses?
6MM OR 10MM
Norm2001,
telectrix,
