Discuss 7" Kitchen Fan.. advice needed in the Australia area at ElectriciansForums.net
T
TPES
Evening All
Ive been to a call out of a kitchen extractor thats packed up..
Its a greenwood AX300 S.
I'm finding it very hard to find any info or anyone who stocks this online.
Does anyone know where i can get a cheap 7" fan, it is domestic, not commercial fan.
If i cant find the exact fan to replace what would you do?
board the hole and cut out 4 or 6 inch hole and just fit a cheaper manrose or something?
Im limited to what size fan i can put in as i would be hitting the water pipes that are very very close to the fan.
Also if too small it will just fall through the hole!
Photos attached..
Evening All
Photos attached..
hi there
you would not have gas appliances in there would you ????????:eek:
if you have put in the same fan in case you fall foul of the ventilation etc of the gas regs :mad:
cheers
Reply to 7" Kitchen Fan.. advice needed in the Australia area at ElectriciansForums.net
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
This isn't very electrical, but never mind! I'm adding an extractor fan to a bathroom in a 4th floor flat. The builder has helpfully cored a hole...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi I connected black wire to neutral and red one to Live one, but extractor fan still does not work. Please see photos attached. Does it mean I...
