Y
youngsparky
Hi,
called to a job today where they have installed a 9.5kw shower in place of there old 9.5kw which was blowing the MCB. There new one is also blowing the 40amp MCB. The shower circuit is also protected by an RCD but on a 6mm2 t+e
I've looked up and a 9.5kw shower draws 41 Amps say but The MCB should hold for say an hour but the circuit is blowing after about 30 seconds. The run of cable cannot be any longer than 15 metres.
IR test all clear
Could they have bought a faulty shower?
Any ideas?
cheers
IR test all clear
Any ideas?
cheers
