M
Monchichak
Hi people,
Setup:
Connect TPN supply from meter to 315A fuse switch (mounted on same surface <3m away) feeding busbar chamber.
Will use 95mm tails.
What gland would you recommend using to enter the cables into fuse switch?
I was thinking to route cables via cable tray but wonder if there is a standard method more suitable?
Setup:
