Discuss AC At Home Anyone? in the UK Electrical Forum area at ElectriciansForums.net
As @plugsandsparks said, keep it above ground level. Get the custom wall-mount brackets and elevate the unit by a couple of feet, slide it away from the wall on the brackets, and it's easy to clean, won't suck up debris, and will be more efficient with clean air all around. Plus, if you are using pre-made pipes, you have wiggle-room as to where the unit goes.
No idea, but ours were mounted on plastic legs:What are the custom brackets like? I only ever see them mounted on cantilevers with zebidees.
These sort of things:
Flexi Foot Friday - Big Savings
Flexi Foot Friday Every Friday Big discounts Big savingsdirectchannel.uk.com
Cantilevers have the advantage the ground is clear below, handy for sweeping out and similar. I guess some channel strut on the wall with anchors or Rawlbolts, etc, would support the arms OK so long as not insanely heavy.I often see big units mounted on feet, but wondered about a neater solution for wall mounting. Periodically ponder the possibility of AC at home and, while I could live with cantilevers, a neater solution would be preferable.
Reply to AC At Home Anyone? in the UK Electrical Forum area at ElectriciansForums.net
